Having some problems
Florida
For some reason when I try to start my cruiser it won't turn over. I just got it a few months ago and it looks like it could use a tune up. Could that be the problem? What other problems could be a possibility? It is full of gas so I know that isn't the issue. Thanx
some ideas, based on what little we know (when it started, any previous occurances, anything you changed recently, etc)
battery
alternator
cloggd fuel filter
ignition
battery
alternator
cloggd fuel filter
ignition
I went out and pumped the gas a lot and it finally worked. That probably means a clogged fuel filter right?
not necessarily, could be a carb problem? though, checking the fuel filter (even replacing it as they are cheap) is not a bad idea. does sound like some kind of fuel flow issue.
By "Won't Turn Over" do you mean the engine will not rotate "turn over" when you turn the key or will turn over but will not start? Tune up could cause "will not start" but not "will not turn over" in my opinion...
X2...If it wont turn over its a electrical/charging/starter issue.
