has anyone replaced head bolt sleeves or tubes before?
Huntsville AL or Yuma AZ
Im in the process of rebuilding a 12ht at the moment and my cylinder head is at the machine shop for check up and new seals and valve grind. I got a call from them yesterday and they told that the head appears to have 6 sleeves or tubes that run horizontally through the head and several of them are rusted through and leaking coolant into the head bolt cavity. This wouldn't cause any kind of external leak but will cause coolant to get on the bolt and if water is used could cause it to rust. Several of my head bolts appeared to be a bit rusty so that explains that. I see no mention of these sleeves in the service manual or any kind of parts schematic. I emailed my favorite parts supplier in Australia and they have the tubes in stock so I have some on the way. My question is has anyone else had to replace these? I don't have any photos of them because the cylinder head shop is an hour or so away from me and I wont get down that way until I pick the head up.
Here are the new head bolt tubes
Those seem cheap and if you are this close to replace I would do that, I never use water as coolant anyway.
I have seen rusted trough freeze plates so might ask them to replace them all, very cheap and if it fails in the car some are very hard to access.
for hj61 find with vin, this is for my hj60:
TOYOTA LAND CRUISER 60 HJ60LG-KW - TOOL-ENGINE-FUEL - CYLINDER HEAD | Japan Parts EU
my logic as well I did find that diagram when I searched for them in the epc but I thought the picture was actually of the dowels for the cylinder head. Would have been much cheaper to order them from my local dealer as opposed to Australia.
Hi Roma,
I have exactly the same problem right now....can you give me the measurements of the tubes or the supplier you mentioned in Australia, that would be helpful.
thanks a lot
Tilmann
