Harrop elocker
Oceanside, Ca
Just imported a Harrop a9378 elocker
Ordering a bearing kit from Nitro
Will post up install, after the holidays.
US$1200 +$200 ship
:popcorn:
Finally got started, wiring loom very easy install. Changed out the supplied carling switch
for a covered switch. Should have locker in over the weekend. DSC_0006.webp DSC_0009.webp DSC_0005.webp
Double check the bearings, some of the harrops are new old stock trd lockers.
Thanks but the harrop website is selling it for 1395 Australian dollars. But sadly it say it fits 80's rear but not front axle. But either way both are sold out.
Still tempted but hard to beat and replace the aussi I just put in and work so well. Do you know if harrop makes a front locker?
Installed! thanks to Just Differentials for the bearing kit. To engage flip the switch under 3 mph..good for up to 20 mph.
Disengage at any speed. Almost instant engage.
DSC_0008.webp Heading off to give it a whirl in the dirt. Now 2X locked, so to you 3X locked....:flipoff2:
They ARE available for 80 series fronts and they ARE NOT sold out - P/N A9334 - send me a PM for more info
The install is the same as a air locker, change out the ring gear, add a new set of bearings.
The wiring was 1.5 hours max, very easy. The wiring loom comes with the locker.
<<<<<<<<< I wonder if you can use the factory dial switch to lock both front and rear diffs. it would look cool. I know others want a separate switch to just lock the front.
Easy peasy. You only need three wires from the diff-lock ECU connector.
This setup will also interlock the system with the CDL, just like factory.
Here you go:
Any comments on the durability of the Harrops ELocker? versus the ARB air locker?
I'm not happy with the Aussie auto locker I have on right now. I keep losing traction to one wheel.
