Harmonic Balancer
Texas
Hello all,
Swapping a 2F into my '70 FJ40. Pulled the Harmonic balancer to replace the front seal and found it was cracked down the hub. Sorry no PIC (camera awol). Will the one off an F fit a 2F?
So long as it was originally retained by the large crank nut, opposed to being the pressed on style found on earlier f engines...
Good luck!
-Steve
Ditto what Poser said. If the balancer was at all loose, you should make VERY SURE that the crank key rests firmly in the crankshaft. You can ask Texican what happens when it isn't.
Yea I saw Butchs' PICS on that.
Found a new balancer and getting it delivered to Round Up ( thanks Jeff ).
It wasn't loose until I pulled the nut. However once it was off I found the key was gone and the crank was chipped at the key slot. No PICS yet. Gonna try replacing the key and then using a cold weld to fill the chip. Thoughts?
Is that not what Butch did? I can't remember yesterday let alone that long ago :D
Chris
