94 Land Cruiser
Just did the oil fix on the dizzy, oil pump cover and harmonic balancer. Used a 300 lbs torque wrench from Harbors Freight with cheater bar to crank to 300 lbs. Then, at 304 lbs, even though the torque wrench is rated at 300lbs. Anyway, after putting everything back, the harmonic balancer is a little wobbly. Cause? Torque is not close to the spec - 304 lbs? If so, where can I get a torque wrench over 304lbs around the Sacrament, CA area? Thanks
