OK- in case anyone is still on the fence about replacing your harmonic balancer, I’ll add my failure. My ‘97 truck has 362k. The symptoms are a *horrendous* clunking noise upon startup, and some minor AC belt periodic squeak-squeak. The clunking noise would clunk-clunk-clunk around 10 times in the first minute, then go away. When the noise occurred, it was so bad that the engine would shutter and rpm’s would drop and pickup. I really thought that something inside the engine was coming apart, and even spun off the oil filter and checked for carnage debris (no metal in the filter, thankfully).
History- So around 50k ago I replaced the engine at which time I looked at the aging HB and said to myself, “Self, this harmonic balancer is built like a tank and will (surely) last forever!” . WRONG-OH.
I’ve since removed the HB and she is toast. The inner hub and outer pulley freely rotate from each other. The only reason that the alternator, water pump, fan, and AC were even getting any rotation was because after a minute of clunking the inner hub and outer pulley stuck together from friction and the belts pulling caused the hub and pulley to mesh.
LESSONS LEARNED: As long as “you’re in there, replace the harmonic balancer. It’s a p.i.a. job to not just replace the HB as preventative maintenance.
On another note:
1) For de-torque / re-torque: I used a home-welded fixture to hold the inner hub. It’s a round 1/4” plate with two small holes to match the hub’s threaded holes, and a large hole in the center to allow the 30mm impact socket to pass thru and attach to the crank bolt. It has a 16” paddle of 2x2 angle iron welded to it. Be careful because the inner hub is inset from the pulley face, so you may need to use washer spacers under the two drive bolts. Otherwise, you’ll be stressing the rubber between the inner hub and pulley as you tighten up the bolts when attaching the fixture.
I used a 4ft long 3/4” drive torque wrench with a 30mm impact socket. It came off at around 400 ft-lbs, so I only had to exert 100lbs on the end of the torque wrench. EzPeeZe
Timing Mark on the pulley- don’t let your old HB fool you. If the inner hub and outer pulley have come apart and are spinning freely from each other (like mine was), your old HB will no longer have a timing reference.
