Hardware color?
Has anybody found a good paint color in an attempt to get SS bolts that brown/bronze OEM color?
Id appreciate ny/all advice.
Thanks
Rob
you mean like this ?
The problem with painting bolt heads is the paint chips off when you put a wrench on them and the extra thickness the paint adds can make getting a socket around them tricky.
If you want to be touching up bolts with new paint every time you’ve got to put a wrench on them and likely struggle to do it - then paint is the answer.
The gold/brown finish you see on the original Toyota bolts is yellow chromate finish applied to cadmium plated bolts.
When it’s new - it looks just like gold. When it gets old and dirty and oxidized- it looks brown.
Nobody applies a yellow chromate finish to stainless steel.
You can get black oxide or drab olive green oxide finish applied to stainless fasteners. That’s what the military uses / so there’s no shiny bolts.
Below is new cadmium plating on old parts with yellow chromate finish.
Replated old bolts never look as shiny as new bolts because the acid dip prior to plating etches the steel.
The company I am using does zinc coating on stainless bolts for one customer. They are "normal" blue color zinc but can be done as yellow also. What is the point on putting zinc on stainless is hard to tell jut it can be done.
And for the starter of the thread. Try to find right color powder coat. It does not chip so easily and does not add so much thickness on the bolt. I have powdercoated myself some ss screws and it works nice.
Thanks gentlemen. I'm talking about this stuff . . .
