Hardtop weatherstripping question
Pa.
I'm about to put the hardtop on my '74,and I'm using the ccot weatherstripping kit.Does any body put any type of caulk or sealer between the side panels and the tub?It lokks like a pretty tight fit,but I don't want to have leaks. Thanks,Bob
I used the ccot top seal (the one that goes around the fiberglass top, not the sides) the first time around, but it sucked because it didnt come with any screw holes and you had to mark and cut the, it was nearly impossible to acurately get them lined up on install.. I ended up shelling out the loot for the toyota factory seals. Good luck.
Mike
Thanks Mike. I got the side on,and it seems to fit fine.I'm going to try the top one tomorrow.It looks like it's going to be a bear!! I might end up using the factory stripping before it's over. Thanks again.
Mountain,
Use a sodering iron point to melt through the hole locations on your top seal. It will provide a good melted seal around the screw or rivit locations and will save you time trying to measure and mark each hole. A good silicone to shore up the rest of the areas on the top seal never hurt.
TexomaFJ40 said:
Mountain,
Soldering iron...great idea.
will have to give it a try when I do mine :D
thanx,
manny 72fj40
TexomaFJ40,You just saved me tons of time with that idea!!!! Thanks!!!!
Weatherstripping
you can use a hole puncher to punch a hole through the rubber where you need the hole. also, use the real rubber underneath the side panels not that stupid 3M foam. A guy posted on there with the same question. My response was not to use it, a few years later i took my hard top off(after restoring it and it looking good) and the foam stuff has adhered to both the tub and bottom of side panels. It made a huge mess and i am going to have to strip the bottoms of the panels and the tops of the tub lips to redo what that tape has messed up.
Spence
mountainman or anyone can you post some pics of the install and weather proofing. I am in the middle of putting the top on my cruiser and would appreciate it. Thanks!
