I have a leak(s) in the rear when it rains..not sure if this is one of the sources but I see daylight on both sides. Is there a seal missing here?
Not sure about the original question but it sure looks like the gasket between the tub and top is missing.....the large one.
There was never a gasket behind the A-pillar of the hard top. Look at your photos and you can see the remnants of seal sealer. That's what you need to reapply.
Thanks. Could I just use a silicon sealant?
You could, but I'd use a specific automotive seam sealer.
No, I'd use something like this:
https://www.amazon.com/Dynatron-550-Auto-Sealer-Caulk/dp/B005RNFBMC?tag=ihco-20
or this:
Eastwood Seam Sealer Cartridge
Its all sealed up now...hopefully this finally solves the leaks.
