that angle would not work an any uni joint would it????
Poser said:" max working angle for a 1350 ujoint" -22 degrees, according to Jess...
I had to go to a 1350CV, and I am running a HI 9....
and IIRC he said max on that was 42 degrees...
Looks awsome Bruce!
Look forward to seeing this in November.
-Steve
wngrog said:After looking some more, is there room for you to clock the Atlas down some? YOu said you had gobs of room under there, that would give you some relief on that angle as well.
wngrog said:Bruce, limit it for now and then send the shaft back to Jess for a 1410 non CV. It does 42* and will never break on you.
He will cut you a great deal on just swapping the yokes. He also has the 1410 Atlas output.
Skip the CV you won't be needing it.
Looks like we nailed the spring rate.
Remember, coil springs are there mostly for the ride height you want. They are not going to be too soft. YOu have PLENTY of uptravel and the truck sits perfect.
I LOVE THE FULL TUB and you have a ton of room for gear too!
I am so happy for you.
Man, Ed came in UNDER budget? That would never happen to me![]()
GreenWeeny78 said:Cool deal. Glad the joints that Mark made up worked well for you. I know Mark is closed to finishing up his 4-link as well. He had a slight set back with his axle falling off the jack stands when cycling the links. We set up the 4 link a little different. The bottom links are on the inside of the frame as well as the top links. Either way it's a clean job hope it works well for you.
Rascal said:Not sure how a larger ujoint would help. I looked under there tonight and the two yokes are actually touching each other and thas sitting flat. If the rear axle droops any at all it's going to bind. My pinion angle is set to 22 degrees. The only way I know to get beyond that angle is a CV on the tcase end.Help me out here guys.
