Hard top paint
Ca you guys direct me as to what type of paint I should use on the hard top and any special prep that may be needed? I tried the search but didn't get much.
Thanks
Colorado Boy-74-FJ40 said:
I used krylon brite white sprayed with a Wagner power sprayer. Turned out pretty good/
That's pretty high tech compared to me covering the rusty white on my bezel with rattle-can white primer...
Kinda depends on what kind of job you want to do. Something quick, use rattle cans and don't look back. Nicer job sand down with 320, repair the cracks. If you have the equipment or have a friend that does, buy a qt of automotive surfacer/primer and some urethane in the color you want and apply. Another approach is to coat the entire roof with something like durabac. That is a urethane-ground rubber mix. It can be sprayed thru a undercoating gun or rolled witha special roller.
