Hard to start when cold
I have a 97 cruiser 167k when it really cold out at first start up its very hard to start and stumbles to start its getting fuel seems like leaks ignition any ideas thanks
Bump for ideas. My 97 with 146k does the same. Brand new battery does help much either. It does this in any temperature that is under about 22* and it's the first start in a long time.
Any ideas would be great. Thanks.
First thing would be to check for any air/vacuum leaks, start with the air intake tube coming from the MAF to the throttle body, they often crack on the underside between the pleats. IME you have to remove it to find the crack but don't yank on it, that can tear it.
Good idea. Didn't even think about something like that.
It really "stumbles" on that first hard start. Holding the key for a few seconds will generally start the vehicle but otherwise it won't. Next key turn will start her right up.
Sounds like I have my work cut out for me this weekend.
Did this ever get figured out. I am having a similar issue with starts after sitting for a while or in morning. Stumbles a little. Runs great after started. Fine if start shortly after cut car off. Only occurs if sits for a while. Just did p0401 code work with new vaccuum hoses, cleaned injectors, new fuel filter, new fuel lines, new gaskets, cleaned throttle body and intake, new charcoal canister. Possibly leak in air intake tube but is new and less than 1 yr old. Any thoughts?
You know, I haven't had an opportunity to research it any further. Oddly enough, if I held the key in the acc position but not on or cranked for at least 30 seconds, it, most of the time, didn't show the issue. Plus on really cold days I'd drive my truck.
As such, my issue was strictly cold weather related. It would happen in like sub 15-20 degree weather
Reviving an old thread - I have this same issue in my '93. I believe its fuel related. If I put the key into ACC and put my seatbelt on and get the kids settled and THEN turn it to start it will fire right up. I.e. its behaving like the fuel is draining back out of the filter and it needs to be resupplied.
This is new behavior in my truck, like its shown up in the last few days and gotten progressively worse. No visible fuel leaks though.
Anyone ever solve this?
Strange…The fuel pump circuit is designed only to be energized when the Mass Air Flow Sensor is in the open position. That would only happen when the engine is turning over.
Well dang, that blows the one theory I had. Now Ive got nuthin, open to ideas though.
Would most likely be your engine coolant temp sensor or your iac valve.
I am not sure mine is temp-related. Its been a chilly mid-60's here lately. I think it has more to do with the work Ive done recently, but not sure what would trigger it.
  1. Cleaned the intake plenum
  2. Reinstalled PAIR system
  3. Cleaned injectors
  4. New plugs
  5. New fuel filter
  6. New PCV valve
  7. Moved O2 sensors back to stock location
  8. New EGR tubes and hoses
It was starting & running really well, best its ever done since Ive owned the truck. But over the last two weeks or so the start has slowly degraded.
This morning I noticed that even after leaving it switched to ACC it still struggled.
Could it be a bad vacuum line? Or the coil going out?
I'm having similar issues with starting lately, long crank times. I did notice a hose that looks like a vacuum line that hooks up on the top of the transmission has split and I've meant to look into it further but almost forgot about it until I saw this post. If it is a vacuum hose it could be related? My MPG has also been down significantly for no obvious reason. Not sure. Seems like vacuum leaks could cause starting issues.
I no longer get my 'high' idle, it generally goes to ~1k RPM's (used to be 12-1400) and settles down to the appropriate ~650 fairly quickly. Not sure though if thats a function of the other work I have done, I moved my high idle from 12-1400 down to 1000 as soon as the work was done, but the slow start has progressed over time.
So last night I found that I dont have a good seal around my PCV valve, so I am replacing the hose with a slightly smaller one that fits the nipple better. Not sure if this is causing a vacuum leak that could be slowing the start. I also temporarily disconnected my EGR system to see if that helps. I reset the ECU to get a fresh baseline. It fired up quickly this morning, so we'll see how it goes.
I have also found that I am getting what appear to be random CEL codes in conjunction with a CEL 71. E.g. first it was a TPS code with a 71. I reset it and then later on got an O2 code and a 71. I reset it and then got a knock sensor and a 71. I did replace the starboard (#1) O2 sensor, but otherwise I just reset the ECU and it goes away until the 71 trips along with some other random code. smh?
I think I am also going to pick up a can of ether today and spray it around the intake area to see if I have a vacuum leak somewhere.
I replaced my too-large pcv hoses and temporarily disabled my EGR. Truck fires up instantly now. I also sprayed starting fluid around the vac lines all through the engine bay and no change in engine speed, so I think my vac system integrity is good. I'll run it for a while to see if I get anymore codes. If not then I'll reconnect the EGR and see if my issues return.
