OK first off I have a 2F that has been desmogged.
I have a Jim C. carb
a non-usa points type vac advance distributor.
Stock coil and igniter.
I have been having a hard start problem for a while now.
Anytime I go to start the truck I have to crank it for a bit, and
floor the gas pedal. Finally it will sputter to life. I don't have any
problems with power or staying started after the truck has warmed up,
but it's been getting pretty irritating.
First, I replaced both fuel filters.
Float level of the carb has fuel in the center of the window, and it
has excellent fuel flow (had the GF rev the engine while I looked at
the sight glass.)
fuel seems to be getting to the carb just fine.
I also improved the ground of the coil. It's now grounded directly to
the battery.
The poitns look good as new.
Dwell is right on at 40 deg. (spec is 39-42deg)
I checked the plug gap. They were REALLY small so I gapped them up to 1mm.
It's still a PITA to start.
It used to be pump the gas once, touch the key, and it would start right up
Now it's pump thje gas a few times, touch the key, floor it, then it sputters to life....
Any ideas?
Thanks!
the sight glass.)
the battery.
Any ideas?
Thanks!
