Hard gum like material on Rock Warrior rim?
Hey all, I picked up a used set of rock warriors on FB for 700 bucks and when I got them home I noticed a hard ish substance around the valve stem. I feel like an idiot not thoroughly inspecting before paying, but I peeled some of it off and don’t see any cracks underneath nor any cracks on the inside of the rim. Chat GPT says it could be bead sealant, anyone got any ideas? Is it a concern?
Imho Yes bead sealant around the valve stem … must have been leaking around where the valve stem seats … usually it’s put on before pulling the valve stem through … however it could have been used after as well
Next tire place just make them aware to check for leaks around the stem after install of new tires… usually they put new stems on … but… many places cheap out these days
You can also check after you get it home by putting soapy water around to see if your getting air escaping
