Having an issue with my 1989 BJ74 manual Transmission pushing it's oil out and into my T-case and then out the T-case breather.
Discovered the problem when I seen an oil spot on the driveway after a long drive on a hot day. After pulling the fill plug on the T-case almost 2 liters of oil poured out before leveling off. Of course this meant the transmission oil was way low.
I've only ever been aware of the opposite problem where the oil goes from the T-case into the transmission and eventually overflows out the shifter housing. I had that issue when I first bought the truck and rebuilt the T-case and replaced the seal between the two cases. I also used the Terrain Tamer kit that connects the two fill plugs with fittings and a piece of hose, which allows any excess oil in the transmission to drain back down into the lower T-case fill hole via the connecting hose
So that was 50,000km ago and like I said its the T-case is overfilling.
Not the transmisiin. Has anybody experienced this? What's causing it? And what's it going to take to fix it?
