H150 input shaft length
zay
New Zealand
Hey all, I'm a bit stuck.
I have a 1990 fj80 glx with a 3f bolted up to an h150f.
I'm currently in the process of swapping the 3f out for a 1uzfe.
I've managed to secure the factory bell housing and associated bits from the manual 2uzfe 100 series Landcruiser that came factory with the h151f transmission.
The issue I've run into is that the input shaft appears to be too short and I'm no longer able to purchase the input shaft that came with the 100 series cruiser.
My question is: are there any other input shafts that I could substitute. everywhere I've looked online suggests that the 3f/3fe and 1hz manuals had shorter input shafts but I don't know if the rest are the same. Length is the only issue as I'm using a uniclutch, so any spline will do.
