Here's what ChatGPT says:
Based on the pattern you described, this sounds much more like an intermittent electrical or wheel speed sensor issue than a mechanical brake problem.
The key clues are:
No warnings until you hit the brakes over a rough patch.
Warnings change with bumps and vibration.
Most warnings clear after sitting still for ~30 seconds.
ABS and TRAC remain illuminated.
The warnings flicker on/off rather than staying consistently on.
On the GX460, the ABS/VSC/Traction Control systems are the foundation for many other safety systems. If the ABS module loses a wheel speed signal or has an intermittent electrical fault, it can temporarily disable:
ABS
Traction Control (TRAC)
Vehicle Stability Control (VSC)
Crawl Control/Multi-Terrain Select (if equipped)
Sometimes even PCS, LDA, or 4WD-related warnings depending on model year.
Most likely causes (in order)
1. Loose or damaged wheel speed sensor or wiring (most likely)
A bump or braking can flex the suspension enough to momentarily open a broken wire.
Common locations:
Front wheel speed sensor harness where it bends near the steering knuckle.
Rear axle sensor wiring.
Connector that's partially unplugged.
This is probably the first thing I'd inspect.
2. Failing wheel speed sensor
An internal crack in the sensor can cause intermittent operation that shows up when the suspension moves.
The ABS computer sees one wheel suddenly disappear and throws multiple warnings.
3. Loose ground or battery connection
Since every warning briefly appeared, it's also worth checking:
Battery terminals
Main chassis grounds
Engine ground strap
A voltage interruption can light up almost every warning lamp.
However, if the battery or charging system were the problem, I'd expect additional symptoms like:
Radio rebooting
Clock resetting
Dim lights
Slow cranking
If none of those happened, I'd lean toward an ABS-related issue.
4. ABS actuator/module connector
Less common, but a loose connector at the ABS hydraulic unit could react to bumps.
5. Damaged tone ring/encoder
If the magnetic encoder in the wheel bearing or tone ring is damaged, bumps can make the sensor signal drop out.
What I'd do next - Read the ABS codes. This is the most important step.
A generic OBD-II scanner usually won't read ABS codes.
Use:
Techstream
Autel
Launch
Topdon
Any scanner capable of Toyota/Lexus ABS diagnostics
The stored code will often identify the affected wheel, such as:
Left Front Speed Sensor
Right Rear Speed Sensor
Wheel Speed Signal Missing
Inspect visually
Look at all four wheel speed sensor wires.
You're looking for:
rubbed-through insulation
stretched wiring
broken clips
corrosion
loose connectors
Because the problem changes with bumps, I'd physically wiggle the harnesses while looking for obvious damage.
Check battery voltage
Measure:
Engine off: around 12.6 V
Engine running: 13.8–14.7 V
Low voltage can cause strange electronic behavior.
The fact that the warnings disappear matters
If this were:
bad brake pads
bad rotors
bad wheel bearing (unless very severe)
the warnings generally wouldn't come and go exactly with bumps. An intermittent electrical connection is a much better fit.
My best guess - I'd estimate the odds roughly as:
60% intermittent wheel speed sensor wiring
20% failing wheel speed sensor
10% loose battery/ground connection
10% ABS module or connector issue
The key clues are:
ABS
Common locations:
Battery terminals
Engine ground strap
Radio rebooting
Clock resetting
Dim lights
Slow cranking
Use:
Techstream
Autel
Launch
Topdon
Inspect visually
You're looking for:
stretched wiring
broken clips
corrosion
loose connectors
Measure:
If this were:
bad brake pads
bad rotors
