GX Dash wiring diagram?
North Carolina
Anyone happen to have a link to a wiring diagram for the GX470? Specifically, trying to find the pin out/wire colors for the dash cluster. Found one for a 4th gen 4runner, but it doesn't match what I'm seeing on the GX.
Thanks. They seem to have everything except the combination meter diagram :/. I believe the 2003-2004 is different than the 2005+, which is why the 4Runner one I found doesn't match (it's a 2004). So I'm thinking a 2005+ Runner would work also. Driving me nuts. All I really need is to know which wire is the VSS input from the SKID controller.
So this doc is exactly what I was looking for - http://4runnerclub.com/i/4r_files/f...07toyrm/07toypdf/07rmsour/4runnerr/052000.pdf
It shows the speedometer input signal on C9-4, and states it being a gray wire with red stripe. Same as the 03-04. Unfortunately, the GX is not the same. That color wire is on the C8 connector. I tapped that with the speedodrd, and it didn't seem to change a thing. So I'll try tapping the C9-4 to see if the connector is correct, even though wire color is different.
Thanks Little-Joe for the link though. Tons of great stuff there.
I have all the factory manuals at home on my PC. Let me know if you still need something when I get back this Friday.
Definitely! I'd hate to be guessing when cutting the factory wires (which I've done to one now already :/). If you have the GX specific diagram for the combination meter, that would be great! Thanks.....
