GX 470 (07) - what to set after battery replacement?
Boston suburb
I put new battery in GX (Sears Platinum, Group 35). It is smaller than original but seems to be secure.
I notices that I can not get the passenger front and driver side rear window down from the drivers' window controls. Is this to be expected? Drivers rear definitely works from its own switch.
How do I reset the windows controls and anything else that needs to be reset after the battery is changed?
Go to each door individually and roll the window all the way down and up a couple times so the car can "re-teach" itself. Same thing with your mirrors adjust them all the way down and up
Correct, You actually just put them all the way down, then hold the button in the up position until it is all the way up and then hold it more (1-2 seconds) to reset each window.
Just did this to mine, worked great.
I dont understand why this is necessary?? My 2000 Land Cruiser doesn't require this. F'n engineers.
