This spring is the first time ive owned my 60 when its hot outside. The last few times ive driven it there is a definite gurgling sound coming from the gas tank and it is under quite a bit of pressure. I can remove the gas cap and relieve the pressure and the gurgling stops. Thre is also quite often a gas smell that fills the garage after getting home. The PO did quite a bit of work on the truck including a desmog. I'm pretty sure its not been done completely correct. I also had a new fuel tank put in at the dealer late last fall. Where do I check first to solve this issue and is it related to something missed on the desmog or something not hooked up correctly after a new fuel tank?
