Guaging Interest - Antitheft harness for 80 series
"the whale's vagina", CA
I am working on building my own antitheft harness for my 80 series. Basically it is a harness I am making that will cut power to the fuel pump when activated. It will have a key switch built into it that switches power off to the fuel pump when the key is turned (barrell key, same as tuffy boxes, etc). The harness will be plug and play meaning that the buyer will not have to do any work whatsoever other than plugging it into their existing harness and drilling a hole for the location of the keyed switch which mounts flush to whatever metal you are securing it to. I am still thinking about where to mount the switch.
Wanted to see if there would be any interest from mudders in purchasing something like this? Pricing would be around $100 shipped, but unsure yet as the key mechanism is expensive ($30). I suppose I could offer a toggle switch version as well. It would be quality made, sautered and use good wire and shrink wrap, protective mesh covering.
Noah
Frankly speaking I think that you might not get enough interest. Most folks here know how to connect a key or toggle switch. The only problem is connecting it in the right spot, which everyone has to do individually. For example connecting the switch somewhere near the steering column is so common that it is no longer an anti-theft method. I suggest folding the back seats and breaking the circuit right by the fuel pump and then routing the cable and switch from there.
Anyway, you offer a product which is just a fraction of all the work involved. The most time-consuming thing is getting to the fuel pump and routing the cable.
you are not messing with the fuel pump or anything else, this would plug directly into the harness. There would be no breaking circuits or altering your stock harness whatsoever.
There are always people whom can do it themselves. The benefit here would it would be all done, neatly and would plug in cleanly to your harness.
Slee offers a harness to upgrade the lights. You can do it yourself but their harness is a no brainer and works great, plugs right in, etc. I bought it and I am a do it yourselfer by heart.
Let me know if anyone else has any other comments, just want to get an idea of interest before I do the research to find the right materials.
Noah
I would be interested, especially in a non-keyed (IE: cheaper) version. As MikePL suggested it would depend on how easy/difficult this would be to plug and play. If it was a quick and easy (15 minutes or less) job, then I think there'd be a decent amount of interest. If you're looking at anything longer than that, then interest will drop sharply.
How are you planning on cutting power to the fuel pump?
I would be interested in a keyed version as it would be easily accessible. I had a fuel cutoff switch that wired in to the wire near the pump and then the switch went out in the middle of a 2k road trip. so after angrily fiding the problem we tapend, connected the hell out if it so theres no way i can get back into the wire itself. This pug and play method would also solve that problem for me.
One concern is if the switch failed like mine did, it would need to be easily remidied ie. removed, splice-able etc.
That contraption is being sold here for years and still cars get stolen. Is a proven fact that if a thief wants your car, he WILL get it. Here we spend $$ in alarms, fuel cut off switches, etc. and still vehicles get stolen. Cheapest deterrent I found so far and is not 100% is a long shackle padlock ($6.00) going through the U joint in the steering rod. I used tha on my 60 and my old Isuzu truck. On the 80 I haven't tried because the u joint is covered. Once you put the padlock there and since is under the hood, the thief tries to drive and he can only steer so far. The drawback is that you have to open the hood to put the lock, and hope you remember is there when you are going to drive.:cheers:
thanks for offering.
Good ideas and initiative always welcome.
Personally, though, I'd rather not have a key. It's probably too conspicuous and couldn't one just jump the wires if it's an interrupt? A little switch someplace unexpected is probably better IMHO.
Have a better idea still, but may patent it someday so yall have to wait for that one... :D
And that's the main problem. Anything that is easily plugged, can be also easily unplugged. Unless you plan to make the plug right at the fuel pump. But anything inside the cabin and near steering column is easy to bypass.
But other than that it's a really nice project.
I like it! .. I think a hidden switch somewhere would be great! I would like it better if when the thief tried to bypass the system, the vehicle would fill with cyanide gas. How much is that option going to be? :)
Could you wire it into another switch like the CDL or rear defrost type. If it looked stock and in plane site a thief might over look it. There are plenty of unused spaces in my dash to fit a switch. Push it in you get fuel, push it again and its out you don't, or modify the key switch to fit in one of the blanks and put a rubber/plastic cover over the key opening so it’s not so obvious.
brilliant idea .. really like that as well. Hidden in plain view!
You'd be surprised at how simple it is to foil a car thief. Just put your t-case in neutral, most car thieves won't likely be able to figure it out quick enough before they bail.
I would highly recommend that you don't leave an unattended vehicle in that condition, for safety reasons alone. Even if your e-brake is in excellent condition, you should chalk the wheels if you ever do that. Not to mention the dead give-a-way of the warning dash light when vehicle is started.
Guys:
Why not save the trouble and just pop the hood and take out the module in the fuse box that disables the ignition but doesn't cause you to lose your idle memory? I saw that here on MUD somewhere.
I'd suspect that most thefts are of opportunity, not the stuff that Gone in 60 Seconds is made of where the thief is looking for an exact model. Maybe I am wrong and I am unaware of what is going on with the 80 Series, so tell me if I am. I'll go to further extent to protect mine!
Explain how a vehicle held with a functioning parking brake is a safety concern.
True, the dash light will come on, but that will most likely not mean squat to a thief.
if parked on a hill, 6,000 lbs of Cruiser is much better held by the tranny and the ebrake than by either one alone.
another good idea for vehicle immobilizing is a manual valve in the fuel line. when closed, the truck won't run for very long.
I think that the product offered here is a decent option for someone who isn't very handy. Better than nothing, easy to use. Too high a price for my taste, but I'm a cheapskate.
