Guages finally installed
Folsom, CA
After much wiring and cutting on the stock gauge opening, I got all my guages installed today ;p
My old stock guage cluster, as you all know, really never provided hard numbers for what was going on inside the engine. With the new Autometer gauges I have hard numbers for my 1975 2F
Oil Pressure at idle 50 psi
Water tempature running, not past 150
Volts with the new CS130 alternator 13.8 at speed
Tach at idle 750
Fuel tank at 1/4 now, don't really know if the fuel gauge is correct until I fill it up and see if the guage is correct. Yes I used the Autometer sending unit but mounted it, spot weld, to the old top from stock sending unit.
The stock panel requires modification..... it must be trimmed. The stock screw tabs that secure the stock cluster in place must be cut out. The upsidedown horseshoe shape brace on the dash just above the steering column must also be cut. I thought about it a good while before deciding to cut the dash.
nicely done :D
I skipped the speedo in mine, and ran an hour meter rather than a fuel gauge....
love the whiteface gauges tho!
Hey Jeff ;p You found the hangout for cruiser addicts :D I hope and pray your daughter is doing better.
So, will we ever see you out in Sac again? Darcy is doing a good job of filling your shoes :bounce:
