Or buy a good parking brake drum.
I will do so! Thanks...The rear of the 1980 and older transfer cases came with a parking brake. If it’s leaking, the FIRST THING you should do is see if you can move the drum up and down. If so, the bearing preload needs to be reset, or no seal will hold for long.
