Ground noise...I think
Albuquerque, NM
Need some help diagnosing an issue. This has been this was since I have had the truck. When the engine is running, I get engine noise in my CB and in my stereo (only while on tuner...USB iPhone connection is fine and CD/DVD is fine). Here is my setup, I am running dual batteries with a controller. The negative on the batteries are always connected, just the positive goes through the controllers solenoid on the second one. I doubt this is the issue, but just wanted to let it be known that I have it out there. I went ahead and purchased a 12v noise isolator for the CB to see if that would help it out...it does not. (https://www.amazon.com/WORKMAN-NF-40-STEREO-FILTER-HANDLING/dp/B00IJZWWWM/?tag=ihco-20)
On the CB, I get much more noise when my lights are on or if I roll the windows up or down. The radio does not seem to care too much about that. I installed an aftermarket antenna on the radio to see if that would help and that did nothing. Also note that the radio did this before I ever even put the CB in. Also the CB is wired to a Wilson 2000 Trucker antenna that is grounded.
I am thinking that I might have a bad alternator/voltage regulator, but did not want to start replacing parts (esp since I know those are expensive since you want to stick to OEM or modify to Sequoia with the brackets and what not) before I asked here for other opinions. What throws me off is that the noise isolator did nothing to the CB so I dont know where the noise is coming from.
I have a led light hooked up with a relay to my reverse lights and it does the same with my radio with it in reverse or if I flip the switch so the light stays on constantly. My radio also makes some noise if I mess with the climate controls like switching from hot to cold or inside air to outside air. I've generally been just dealing with it, and am kind of thinking it's just the fact that aftermarket radio in mine is junk since I barley get reception anywhere compared to other vehicles. I would be curious also to see what comes out of this discussion
I too have minimal reception, both on radio and on CB. So I put in LED headlights, but this was happening way before that. On the taillights, I my reverse are LED and my stop/park rear bulbs are also LED, however this happens even if none of them are on. What is interesting is that if it was a real ground issue, I would expect the noise to be there, no matter what input I was using on the radio. Since this only happens on tuner and on the CB, it leads me to believe it is somehow RF related. I am thinking that it might also be why my reception is poor.
I know you said you changed antennas. Mine is the stock powered telescopic one and it doesn't go down just makes a thump noise, so idk if that may be the issue. It also crossed my mind that it could be the cheap Chinese relay I'm using or the body ground for the led light circuit but like I said it does it with my climate control as well. I've had bigger issues to deal with on my rig so this minor inconvenience hasn't gotten to me yet, but I could see how having a cb and just getting constant static feedback would make me want to fix it as well.
I could try to hook up a regular halogen or whatever light to my led harness and see if it still gives me feedback through my radio. Or just disconnect the light all together and flip the switch to see if I get feedback. I'll probably try that tonight when I leave work.
My usb plugs when in use seem to mess with the tuner on several of my vehicles with both stock and aftermarket radios. Do you have anything like that in your truck?
All I have for usb plugs is a cigarette lighter adapter one which makes no interference and the one on the radio itself which is usually only used for music so the tuner isn't being used anyway. I think I've used it to try to charge my phone before with using the tuner and it didn't mess with the radio but was horrible at charging so I haven't really used it since.
I do have led dome lights and those don't affect the radio ethier
You can't really hurt anything by hooking a ground to a ground.
If you run a ground wire from the engine block to a fender, it shouldn't make a difference.
HOWEVER, it might make a difference to your radio antenna, and it's reception.
Use an alligator clip wire like
If it doesn't change the reception, try somewhere else.
I'd try the body panel your radio antenna pokes out of.
Try connecting the CB chassis to your seat frame, or a known good ground nearby.
Unhook potentially noisy lights (LEDs (actually their drivers)) and USB power supplies. It's all about the signal to noise ratio.
So if unhooking the lights solves the issue then what remedy would be needed to fix the problem? Like op said he has led tail, head, and reverse lights. So unhooking them may solve the issue but it doesn't fix it since now there is no light(same with my reverse lights bar). Would noise isolaters have to be installed on the led driver's?
It's usually better to kill the noise at the source. So a condenser or capacitor across the power leads as close to the LED driver as possible.
You could also put an RF choke in the supply line going to the LED driver.
I can hear my OBDII reader (ultra gauge) communicating when I try to listen to AM radio. Sounds like horses trotting, but not quite, if you know what I mean. Dddrt - dddrt - ddrt - ddrt - - - dddrt - dddrt - ddrt - ddrt --- etc.
Antenna height makes a big difference at times.
Damn cheap chinese light bars....
AM will pick up almost anything along with static and solar flairs.
My question though is, if ALL of my LEDS are off, it should not cause interference. This does it day or night, with the LED's on or off.
Did that fix your issue @RyRoRyan ?
I discovered last night that I was at the gas station with the radio on. I placed the truck in reverse and the radio went all static. I took it ouit of reverse and it cleared up. Lather, rinse, repeat. Every time I placed it in reverse, the radio went static.
I have LED (PFRAN) reverse lights, but nothing else. I have the stock power antenna (with a bent mast.....) but the head unit is an Alpine and has been in the truck since I bought it 7 years ago.
I am open to suggestions.... I'm NOT an electrical guy, but I can work through it if someone tells me where to go......
EDIT:
I may have just found my answer....
LED Headlights Anterna RF interference
