Grinding snap ring groove.
Western, SD
I just got my Aisins in the male but I have the later birds so I need the in board snap ring groove. Has anyone ever attempted this with the birf still in the truck? I would think there would be plenty of room to work. Time is a premium around the house with two young kids and working nights so if I can cut out the greasy tear down it would really help. What do you guys think?
Easy job for a Machine shop. How are you going to ensure groove is straight ie you need a guide and what are you going to cut it with?
Hope this isn't a classic example of "Act in Haste, Repent at your Leisure", but let us know how it turns out.
You could use a piece of tubing as a guide to ensure straightness but controlling depth will prove very difficult. Going too deep with that tiny, rough radius at the bottom of the groove that a cutting wheel will produce will create a stress riser and possible weak spot.
I agree with Hornd, take the time to do this right. I totally understand and remember two young kids and working nights. Glad that's over! :bounce:
I was hoping someone would chime in who did not have it machined and did it themselves. Will see when I tear into it if I feel like I have all that is needed to make the notch without damaging the birf.
What tooling to you have to make the groove?
It's one thing if you or a buddy have a lathe & can chuck it up, completely another if you're eyeballing it & using a Dremel.
I'm all for doing it yourself, provided you have the right tools / fixture.
Otherwise leave it for a day at a local machine shop, it's not anything to get it cut once right & if you screw it up not only are you going in again, but waiting for & buying labor to get your shaft fixed or shipped a new one.
I used some blue painters tape and a angle grinder measured 3X iirc 12-13mm. From edge of birf .
use the other groove for reference on how deep to cut into. Not as difficult as you think
Never had any issues.
