Green frothy front diff fluid in every single change listed below for the past 10k miles. I apologize in advance for the lengthy post. I don’t post nearly as often as I lurk, but I would really appreciate some help on this one.
174,300 Change Front and Rear Diff Fluid, Birf Repack, Toyota Inner Axle Seals, 4.88s
174,750 Front and Rear Diff Fluid (ring/pinion break-in)
175,403 Front Diff Fluid
176,100 Front Diff Fluid, Birf Repack (No soup), Marlin Crawler Inner Axle Seals, No wear evident on previous Toyota Seal. Very slight grooves in seal location of axle shafts (shiny ring only noticed by dragging a finger nail across the shaft)
176,950 Front Diff Fluid
178,880 Front Diff Fluid
181,600 Front Diff Fluid
Comments:
1/ Screwdriver test in the knuckle check hole always looks like the synthetic valvoline moly that is slightly thinner than what I keep getting all over myself during the repacks. I don’t know if this is due to the grease somewhat breaking down under temperature or due to diff oil contamination.
2/ Diff breather flappers eliminated before re-gear.
3/ No leakage of diff oil from the knuckle wiper seals.
4/ Re-used knuckle bearing shims in factory locations. Replaced knuckle bearings and properly tapped in new races during re-gear.
5/ Used sealant b/w 3rd and axle housing as opposed to OEM diff gasket. (don’t think that this would allow enough mis-alignment of the axle within seal to cause an issue but I thought I would state the fact.)
6/ There is no possible way that this green diff fluid is from old grease in the axle housing. I cleaned out the housing when the 3rd was out, and I sprayed brake cleaner into the housing tubes flushing everything out of the drain plug.
7/ New wheel bearings rechecked multiple times without play.
8/ Spindle bushing is original; looks to be in excellent shape although I did not measure.
9/ Birf joints tight, never a click, swapped sides during re-gear.
10/ When I’m not wheeling, I drive fast. I do a lot of interstate driving at 80mph. I say this because my hypothesis is that:
I think something is slightly worn or bent causing a slight misalignment in which the seal can easily account for at rest, but at high speed this misalignment causes a “whipping” motion of the seal thus allowing grease/oil interchange.
I was hoping that one of the ridges on the ID of the inner axle seal would be worn so that I could identify the misalignment, but I didn’t notice anything before most likely because I reacted too soon. I am hesitant to tear into it again with only 5k on the Marlin seal.
When and what should I do/check/measure when I teardown the front yet again?
I am tempted to be cheap and just change the diff fluid every 5 or 10k with Costal 80w90 to keep the new 4.88s in decent shape, and then do a repack when the knuckle grease gets soupy. Any of the more experienced folks agree/disagree? Thanks.
Comments:
