Greasing Tatton front DC shaft.
Shoulda rode with ME last week! I have a Spicer DC on my front shaft. I grease the center swivel pretty often since it is not protected as well as the needle bearings in the crosses. I use the needle as per Tools. First time is a painintheass, but not so bad once you figure it out. Using a mirror and a light, rotate the driveshaft as you hold the mirror above the DC. Watch between the yokes and you will see a small gap between the center covers when you get to the sweet spot. It is just big Enugu to introduce the grease needle. I put about 8-12 pumps of Green Grease on there. I also painted a white stripe on the very bottom of the DC body at that point so I can always find the sweet spot. It only takes me a couple of minutes to grease the whole shaft now.
I just bought something similar.
So are you guys using the flat zerk or just slipping the needle into the joint passed the dust cover? That seemed almost easier than trying to line up the zerk.
Line up, push the zerk ball in and pump grease. Flat or regular zerk, works on all of them.
I remove mine. I’ve decided to do this with both of my driveline’s because they are both DC. Removing them allows for easy access to the fitting in question, and allows me to clean and lube the slip joint without the risk of filling the end cavity with grease and having the plug pop out. I don’t really believe the slip joint can be properly maintained any other way.
