- Joined
- Jun 5, 2003
- Threads
- 110
- Messages
- 1,847
- Location
- Sacramento, California
- Website
- www.instagram.com
When I replaced the stock front drive shaft that came with my cruiser for Slee’s dual cardan front drive shaft, it came with warning label that said pretty much this: “Warning: Lube every 3000 miles or ELSE!”.
What makes this drive shaft special is that it has 3 joints. One at the front differential and the other two at the transfer case side of the drive shaft. This setup makes it possible to connect the front axle to the transfer case after the vehicle has been lifted. Using the stock drive shaft on a lifted vehicle can create some nasty vibrations.
It was quite easy to locate and lube the zirc fittings on the joints of the shaft. However, there is a fitting, different than the other fittings, this one looks like a hole. It sits between the two joints on the T-Case side of the drive shaft. I had seen it when I installed the drive shaft, but once installed it is impossible to get to.
I purchased a needle nose tip for my grease gun so it would couple with the special fitting between the two joints.
After much thought there the only way to get grease to the middle fitting was to at least disconnect the front side of the drive shaft. If that didn’t work, I would have to remove the whole drive shaft just to lube it. I was not looking forward to that.
Anyway, I got under my truck with the necessary tools and in a few minutes and with the help of a rubber mallet, the front side of the drive shaft was disconnected. I placed a couple of chocks under the tires to avoid movement and then placed the T-Case in neutral. That allowed me to rotate the front drive shaft while still being connected to the transfer case.
I found the special fitting, but to get the needle nose tip, I had to open the joint as much as I could. With the help of a bungie cord I kept the drive shaft out of the way while I greased the joint. I pumped until I saw new grease come out.
After that, all I had to do, was bolt on the front side of the drive shaft and I was done.
From beginning to end, this project took me about 90 minutes.
