Grease streaks on outer wheel
Houston, TX
My 96 has started getting radial grease streaks on the outer pass side wheel. Not total mess but about 6 or 7 thin streaks. Axel was rebuilt about 20k miles ago by PO ( not dealer). Does this mean its due for another seal job or could it be something easier than a complete rebuild. Knuckle is full but seems very thin. Drivers side is fine. Thanks and Merry Christmas.
Merry Christmas. Inner axle seal has failed and your grease is now is gray soup mixed with 90w....sorry for the bad news, but it's back to square one. There is a great write up in FAQ......DIY.
Use Marlin Crawler seals from Slee.... Some will disagree, but I've heard nothing bad about them.
Mine failed a few days ago. Still driving it praying it lasts til I can deal with it. For me its leaving onto the rotor hub and is burning something fierce.
If the OUTER side of the wheel is getting streaked, the drive flange gasket isn't sealing. Molybdenum disulfide grease is thinner than most other types of grease. Try that first before you get too deep into it. New inner axle seals shouldn't fail within 20,000 miles.
Pin Head - Yes , streaks are on outside of wheel. I know you are suppose to use a moly grease in the knuckles. Are you saying to try something else?
I agree it's a failed axle seal. Pretty typical symptoms on 80s.
gotta agree with pinhead here- if axle seals are shot you should see the same grease on the inside of the wheel/brake/steering knuckle. Maybe you have both problems?:mad:
good luck
Either the drive flange gasket or the cap is leaking. The axle seal could be bad too, but it wouldn't be leaking on the outside if the drive flange gasket and cap were sealed.
The point is that it is easier to check the cap and gasket first.
One thing everyone should watch for is the flatness of the drive flange when reassembling. Typically you need to whack the crap out of the flange, hub and studs to get the cone washers to come free. This process can distort the edge of the flange and then not allow it to seal properly on re-assembly.
I always take a file and run it around/across the flange to ensure it is flat. I often do find high spots and need to file them down slightly. This also goes for those with rear full floaters only you file the axle shaft flange.
Toyota Part 43423-35010
OEM Toyota CAP, FR AXLE OUTER S
how can i be sure that this part will fit my fj 40 82 ?
anyone ?
