I noticed oil on the under side of my 4runner, it would appear as though it is leaking, spraying, from the companion flange of the rear drive shaft, so being the nifty mechanic that I am I replaced the oil seal on the output side of the transfer case but it is still leaking. Would it be safe to assume that the flange is worn thus allowing oil to leak past the new seal? The truck is an 86 4Runner 5spd with well over 200k on the clock. I've heard that the transmission can actually pump oil into the transfer case when a seal goes out which would over fill the transfer case, if this has happened to my truck would this be one of the symptoms? I do not have oil leaking from any other part of the transmission, jut the rear companion flange, would over torquing the flange nut cause this issue? Oh and yes I did put sealant on the flange splines when I installed it.
Sent from my iPhone using IH8MUD
