Got my injectors back from RC Engineering
On your Mama's Bed!
Website
www.theharshtruth.com
About 1 1/2 months ago the Cruiser developed a miss and threw off CEL Code PO300(random missfire detected) & PO306(missfire detected on cylinder 6).
I went ahead and decided to replace the spark plugs and wires. Upon inspection during removal of old plugs, I noticed that cylinder 6 spark plug was black and a bit wet while the rest were burning pretty well as I had hoped. The rig ran great after the initial install of the new plugs and wires, until a day of local driving. Unfortunately, CEL Code PO306 came back at the end of the day. A definite miss was still noticed during acceleration until I reached freeway speed. The miss felt like it could've been fuel starvation. I read a few post that some of you had posted with having similar problems, and someone suggested swapping injectors would be the next test. Upon inspection, swapping 2 injectors was going to take the same amount of work as removing all six. With 132xxx miles on the clock, I guessed it wouldn't hurt to get the injectors cleaned so I decided to remove all six & sent them to RC Engineering for a cleaning, balancing, and blueprinting. Here is the "before" and "after" data that I got back from RC Engineering. I'm hoping to get the injectors back in by this weekend and see how well the Cruiser run after all this. I will keep you all posted how it turns out.
While you have it down and easy access to the engine harness, you should carefully inspect the wiring harness as it passes by the EGR valve. Also check behind the glove box. IMHO, your "before" results don't look bad enough to account for a P0306.
When you reinstall, wrap the engine harness with a quality heat tape in the area of the EGR valve.
-B-
LX_TREME said:
Question, How long does it takes for them to do it, Do they offer 24 hrs next day, fast service? Also how much do they charge for blueprinting, cleaning and balance each injector?
Thank you.
Got them back within 48 hours(2 business days). I sent them up to Torrance on the Saturday of Labor Day weekend, and got them back on Tuesday. Monday was a holiday.
The cost was $154 shipping included.
$24 per injector, plus $10 to ship back to me.
Thank you.
Ditto
Beowolf,
You brought up a sore spot for me.
When I removed my EGR valve to clean it that harness was staring me down.
The whole time I was thinking to myself, here I am trying to cheap out of paying someone else to fix this and I may end up breaking this awfully important looking mass of wires. What quality heat tape are you referring to sir? hijack over
landtank said:
MAF offers a swap program for injectors and uses RC to do the cleaning. You order the injectors which include a deposit and when they receive your old ones back they credit the deposit back to you. Worked real good for me.
Ooo thats good to know!
LX_treme (and anyone else that is local) if you physically drop off the injectors when RC opens up you effectively cut the cue to first in line since the UPS drop isn't until about 10 am. That way your's gets done first and they had mine ready same day by 3:30 pm and I dropped them off just after 9 am.
I've done this twice and it is easy wrenching as Rick points out. The tough part is deciding what else you "should" do while you're at it. Fuel pressure regulator, fuel filter, etc. But at the minimum it's a good time to thoroughly clean the top half of the manifold plumbing and the throttle body.
I am going to do this when I get to L.A. Torrance is 30 minutes from where I'll be (depending on traffic possibly two hours, gotta love the San Diego parking lot aka the 405):D
I had (6) Buick Grand National 36lb/hr injectors cleaned wit flow sheet by a Buick GN vendor that only charged me essentially half that RC Engineering cost which included the return shipping. This was back in 2004 though.
I have sent him an email and after confirming he is still around, still performs this service, and the current cost..... I will post up his info.
Got a confirmation email from Chuck and he still performs this service.
Here is the contact info:
owner- Chuck Leeper
Cody Motorsports
1995 Plantation Rd. SW
Lawrenceville, GA 30044
770 995-1106
4cyl $60
6cyl $80
8cyl $100
if someone wants 2 sets of 4 cylinder injectors done he will only charge the 8cyl price. Add $8 for return shipping with insurance.
He did a great job with mine. Cleaned, flowed, repainted, flow sheet and fast turnaround time.
The good stuff can be bought on-line at Summit Racing, Jegs, and others. I found it at a local speed shop.
Thermo-Shield aluminized adhesive-backed tape is great for wrapping the hoses and wires you don't want to remove. It can also be wrapped around odd-shaped components for lasting heat protection. Wrap it around a fuel line and say goodbye to vapor lock. It reflects radiant heat up to 2,000 degrees F.
-B-
Thank you ;)
How fragile are the injectors with consideration to how they should be packed for shipping? Any chance they could be easily damaged in shipping?
Any reason NOT to replace the filter and regulator while in there?
