Got a little pinging going on . . .
Worland, WY
Supercharged the 1FZ a couple months ago. Has a fresh head gasket and 280k on the odo. Injectors were new at the end of 2015, along with a fresh fuel filter. Haven't checked the pressure but I'm planning to drop a new pump in since the seats are out for upholstery. Runs great and I'm enjoying the extra power. My CEL has been on since I deleted the cats and the after cat oxygen sensor, along with the EGR.
Anyhow, here's what I have planned to eliminate the detonation:
-fuel pump
-sea foam
-snorkel(cooler IATs)
-colder plugs(MR2 ? ?)
-Methanol injection setup(probably should be at the top of the list).
Am I missing something ? What meth inj set up are you S/C guys running ? Links ? I'd love part #s for the colder MR2 plugs too if they're handy. You guys have been tons of help so far.
Have you checked your timing? You should be at 3 or maybe even a degree or two lower for SC.
Are you using premium gas? That's also recommended.
Snorkel surprising to some does help with intake temp as Mr T originally designed it to do but I doubt that's the source if your issue.
I'm running 91oct and have been since a month before the S/C was installed. I had the timing set at 6° initial but set it at 3° post S/C. Guess I may need to go 2 or even 0 degrees . . .I know methanol injection will probably help the most, but I'm not sure exactly what set up to pick up. Should have been thinking colder plugs when I was planning it all out too.
Plugs are light brown and look great. Figured I'd see damaged electrodes on the cylinders that are knocking, but I think the ECU is pulling timing and no real damage is done yet. I'd just like a buffer in case I get some sub-par fuel somewhere(which I think may be most of the problem). I'm distrustful of some of the places I get gas. I travel quite a bit and this is my DD(every other week actually) and I cover 800+ miles a trip. Sometimes more.
I think I hear it mostly on slight inclines while cruising. Sometimes on acceleration between 1500 & 2000rpm. Like it wanders up and down at those rpms and I think that's the timing being retarded slightly. I'd ideally like to fix it w/o meth injection . . .but I'll go that route if necessary.
Any indication of carbon buildup in the cylinders? Excessive carbon will increase the compression ratio beyond stock and could contribute to pinging. This is probably unlikely since you put so many highway miles on it but worth asking. Before messing with Seafoam I'd recommend doing the water into the vacuum line procedure to clean out any carbon buildup. Do this with a hot engine to maximize the steam clean effect.
It sounds like you are doing all of the right things and its possibly a fuel issue (supply or quality). Are you having any misfires or issues with fuel flow? It can't hurt to swap out the fuel filter if that hasn't been done (do this before messing with the fuel pump).
I run NGK BR7e plugs and 87 octane with out issue. Thet are 2 heat ranges colder, copper which disipates heat the best and like 2.00 ea. However they need to bw changed out more frequently.
Id get a set locally and give them a try
Thanks. I just picked up 8 of these off Amazon. I'm sure it'll help. Replacing them often won't be an issue. Would be pretty sweet to run 87oct w/o issue.
@ZackR, I'm not sure on the carbon build up, but I cleaned the combustion chambers and piston tops when I did the head gasket 12k miles ago. I'll have to run a little water in through a vacuum line and then check with a borescope I just ordered. I'll do a before and after inspection and get pics. The fuel filter has about 35k on it and I plan to replace it along with the pump.
Don't do Seafoam.
Do you need to change / fix your knock sensors?
Don't do Seafoam.
That's a possibility. It's bank 2 where the code gets pulled and I had a buddy help with the head gasket. Hooking up the PHH may have messed up that knock sensor too. Idk. Not easy to get to.
All I could find available for NGKs is BR7ESs, which aren't correct. BR7E didn't show up . . .
Any recommendations on plugs or part #s ? Like the MR2 plugs I read about ? Wanting to get swapped to colder plugs this afternoon.
Thanks @landtank, I've got the 4644s in hand and a pile of BR7ESs for sale if anyone is interested :rofl:
