Getting my steering wheel straight
Fayetteville, AR
My steering wheel is not at the zero position when I drive in a straight line. It is tilted to the left. I've recently has my car aligned and the alignment seems good, the car fades slowly to the right like it should. I've read that adjusting the drag link will straighten up the wheel but wouldn't this throw my alignment off? Or should I just pull the wheel and line it up myself.
Either way will work, but if you adjust the drag link, when you get the wheel centered, make sure that you can turn lock-to-lock.
Ed
What I do is pull the wheel and get it as close as possible then, if need be, do a minor adjustment on the drag link.
Since you had a alignment done, one would think they should set the wheel straight??? Anyway.. The method I use... after all else checks out correct... remove steering wheel and set back on the shaft loosely and take it for a drive...while driving down the road.. lift it up and re-set it as needed... replace nut and remaining pieces.........
"while driving down the road.. lift it up and re-set it as needed... replace nut and remaining pieces.........":eek:
That's a joke right? Not a bad idea, but please make sure you're stopped first.
Kevin
I would, however the shop is in Dallas and I'm in Fayetteville, Arkansas. I had it done over my Christmas break. I don't think fixing it myself should be that bad though and I'll probably do a better job than they would, considering they messed up the first time.
That's what I like, someone who's not afraid to drive their LandCruiser a few miles...
It is not a big deal to adjust it. If the threads on the rod end are rusty, soak them in penetrating oil and use a pipe wrench to turn the rod until the wheel is centered. This is the proper way to center it so that you don't run out of motion in your steering box in one direction.
Ok I think I'll try that before I pull the wheel...if I want to turn the wheel to the right to center it which direction do I need to turn the drag link rod?
Turn it to lengthen the drag link. The problem with the other ways of centering the wheel is that the box itself may not be centered and you will run out of turning radius in one direction. In other words, it will turn more to one side than the other.
