Getting 40 doors off
Plant City, Florida
Has anyone made a special tool for getting at the top-most bolts on the top hinge? I cant get the ratchet in that tight space with a socket and a normal 12mm box/open end is too short to get the leverage i need to brake those bolts loose. Do I need to fab a long handle on one of my 12mm?
have you tried a gear wrench or other similar style ratcheting wrench?
Fixed or swivel end? Last time I pulled hinges I didn't own any gear wrenches. Now I have three sets of swivel end gear wrenches in SAE and metric so always have them close by. Wonder if a set with a fixed offset might work better. Have some boxed end wrenches with different offsets I've used in the past. The offset allow more room for the hand from the back of the dash and still have the wrench flush on the nut.
If you just want to remove the door and not the hinge, just drive the hinge pin out.
I was just about to ask that. So now I know I can just drive out the hinge pin. I’m planning to put Metal Tech doors on, do they use the full stock hinges to mount?
If you are removing stock doors and installing MT tube doors, you do not need to remove the hinges from the body. You only need to remove the stock doors from the hinges. Does that make sense?
That requires folding the windshield forward for the pin to clear. Scraps the paint on the windshield otherwise.
I ground a bevel on top of the hinge pin to avoid some of that scraping to fit my half doors..
^me too for the 40. I’m going with the quick hinges on the 45 when the time is right,
you can just cut the stock hinges and they work like fst hinges unless the quick hinge is stronger
i just did some on a junk 77 i had i used a 90 lbs air rachet with a 6 point 12 mm socket on it
I just took the advice above and removed the hinge pins but they didn’t wantg to come; put a chisel and a strong hammer to get them to separate a little then liberally applied PB Blaster; a few minutes later I was able to tap them out.
