Gears - Which ones?
Tulsa, OK
Zuk Recomends Nitro
IPOR and Cruiser Outfitter sell Sierra Gear.
Sam's Off-Road - local option for install - uses Yukon Gear.
Are any of them bad quality and to be avoided?
I ordered my gears from JT, a vendor here on mud. They sent me 2 diffrent brands nitro and precision gear. They said it's what they recommended for my Lx450. so far no issues there.
-Juan
I know Robbie is using the Nitro gears and has been very happy with them.
I would also recommend Carl at JT: I emailed him about some gearing questions and he was very quick with responses, customer service, etc., even though in the end, I was not able to get gears because of outside reasons.
Zuk--as mentioned--recommends Nitro as well.
Used Yukon's in my last 5 rigs.
The guy who taught me to do gears, used Yukon's only with over 70 installs, not one manufacture related failure (did have a locker blow up and take out a set..but not the gears fault).
No experience with the others. Both my current rigs, have Yukon's in them (4.56's in the 40, and 5.29's in the 80).
BTW, I only order through completeoffroad.com. Seems to have the best pricing I found, even cheaper than our dealer account with Randy's R&P.
GEARS
Nitro is preffered by JT's, Zuk, Slee, Cruiser Outfitters and more. We have used others as well, but I am 100% confident in the Nitro gears. I have removed Yukon's from my own vehicle for noise issues, and I am sure others will chime in as to past noise issues with yukon as well. Most vendors, dont know the difference between an fj40 and a uzj100 and view Landcruiser gears as c or d movers. We view them as A movers.
gears
That is because LC gears are their D movers. If you need some, I have plenty in stock.
thought 8" HP reverse cut are out of stoc in Yukon right now ..
Nitro has been good to me so far.
Advise: Dont go through a vendor that doesnt deal with them on a regular basis. I went through a major name 4wd retailer and had to go back twice due to the wrong product being sent and finally getting some of the gear kits from another manufacturer.
Mix and match, didnt save any money, wasted time while the axles were apart. :frown:
If I were to do it again, I would go through a vendor that knows what the heck they are talking about and dealing with (like some of the vendors on this board) and order from them.
Also, go with whatever Zuk recommends. The man speaks from experience!
Curious ~ what tire size do you have and what gear ratio are you considering?
I've never heard of a bad experience with any brand of gears. It's my opinion that all ring and pinion gears work well, regardless of brand.
It all depends on quality control. The feedback of the customers is a dead give away of that. Make sure that you read a lot before going through with the purchase. When making any major purchase or when getting something that is somewhat critical i always do a lot of research, i find it helpful to read info from other sources. Maybe check out some forums that deal with other vehicles and see what they think of the different brands. If one stands out as being good across the board go with that.
I've had good luck with Genuine's G2 series gears. They are way higher quality than the entry level Genuine gears, and seem to be quieter than the Nitro's.
Ken (aka Zuk) was impressed with their quality as well when he installed them for me (Toyota gear install)
37's and 5.29's
I saw that, where did you get the G2 gears from?
All- thanks for the info. Like has been said, it's a big purchase, and I don't want to make a thousand dollar mistake.
I'm leaning toward having Zuk do the work with Nitro's, which is a big cost, but it doesn't do me any good to save a couple hundred bucks to have one fail and screw up my locker and such. I'll likely hold off just a little while longer to put a little more money away, and let the weather get consistantly cycle weather so I can have the truck down for two weeks. Was trying to do it at the same time as front end service to keep from haing to pull axles twice, but I'm just going to have to do it twice.
Thanks all for the input, and if anyone else has more experiences to share, please, pipe up!
5.29s are a bit of an install. I had to grind the housings for them to fit into it and the pinion depth was quite a ways from the stock depth. If you aren't setting them up yourself definitely find someone who has and you trust.
I too had to grind the rear 3rd in mine. Was not a huge deal, about 5 minutes and it was good to go. This was the rear end which is a late model full floater.
You also have to grind/bevel the cross pin (stock pin, stock carrier) to clear the thick ring gear in the front. Again, not a huge deal but will give you a shock if you haven't experienced it before.
If this if your first time install...it is best to have a very experienced hand help you/show you and walk you through it. Or pay to have it done if you have no interest in learning, however LC diffs are one of the easier ones to setup...not at all like a dana!
Good luck.
