GEARING FOR 35s
Moab,Utah
:confused: I am considering changing my gearing , on my 40, to make it pull 35's better on the hiway. I have a 2F
4.11 gears . can i please get some input thanks Dennis
i
Welcome.
Change your gear ratio once...you will not stay with a 35" tall tire...
4:88's are in your future.
Swap in ARB air lockers while you are at it. ;)
Good luck!
-Steve
steve, igot lockers , ijust need to see if any one went with 4.56 with a stock motor and a 4 speed that run 35's. i am also sprung over.
i read some stuff on gearing 100's . that had auto transmission and running 35's . this guy was trying to get it to pull better on the hiway
Dennis-
You really need to think through the idea that larger tires may be in your future, and in which case, if they are, you certainly do not want to spend the same money twice to only end up where you would have been in the first place. Re-gearing is not cheap, period. It is something that you only want to do once. Since the 4:11 ratio was sent here with a 28” tire from the factory, going to 4:88 is really not that large of a leap to push a 35 or larger down the road.
Even if you do not see yourself running a tire larger than a 35, there is no way that I would gear the truck with 4:56. The difference is not that big on paper, but it will show how big it is in your wallet when you press the re-do button.
To each their own.
Good luck!
-Steve
lowtideride's has 4.56's in his 60 with 35's and fully locked as a daily driver... but he had the stock 3.73's so 4.56's wouldn't be a great leap from 4.11's just to it once get 4.88's and run 36's for now until you get that "feeling" and switch to 37's or 38's.
- he does like his 35's and 4.56's its nice and low but still good enough for DD
Something to consider
I swapped the original 3-speed in my cruiser for an SM420.
2nd gear in the SM420 is lower then 1st gear in the 3-speed.
First gear in the 3-speed is 2.76, second gear in the SM420 is 3.58.
I am running 4.11 gears in the diff and 35” BFG mud terrains. Taking off is easy on the clutch and with the 35’s, running in 4th gear is like having an overdrive. The only disadvantage I have seen with this set up is the jump between 3rd and 4th gears is a little large.
I am planning on re-gearing the diffs when I go to 38” swampers, but the cruiser won’t see much highway time after I go larger.
I know this option is as expensive if not more then re-gearing the diffs.
4:88's put me back to lower than stock, with 38.5 inch swampers and a 2f and 4 speed tranny
I appreciate the help every one . I am still going to ponder this one out. Also i liked to know of anyone useing longfields, I need to replace a berf.
Hundreds of people are running them, and have been for many, many years.
Bobby has come out with a 30 spline upgrade kit.
Get it, and don't look back.
:beer:
im about to put 4.88's in my 40 with 35's, i dont care for speed so it just doesnt matter, i do like 50 anyways!
but ill tell you how it is once im done
