Need a new starter for my 40. I’d like to go wit a gear reduction starter but in searching the threads I don’t find a part number for 1970 FJ40. Looks like the 28100-60070-84 will fit. Can anyone confirm this part number is correct for 1970 F motor?
Thanks for the replies. I thought that one would work with all 40 series but wasn’t sure.
You'll love it
….Will these fit a 7/69 too?
I show the gear reduction started 6/82 in 40 and 60 series. It doesn't show it being sub for earlier models. While it will work it's the wiring may be different and not a simple plug and play. But not a major rewire either.
With the new GR and Dizzy, on a cold start, I am one pump and one bump on the key at 1/2 choke.
I’m going to be ordering one of Matt’s little beauties as a Father’s Day gift to myself this week. Unless of course I am successful in dropping multiple hints that this would be a great Father’s Day gift in which case my son will place the order![]()
yes ,
1962 Siamese F - 9/87 2F and 1988-1990 3F and 3FE
we offer the Genuine NipponDenso gear reduction starter as a complete all inclusive plug and play KIT :
- NO Core fee or trade of your old tired unit is involved or required to be very krystal klear here to begin with , your local TOYOTA Dealer will charge you $75 in
a core charge when you .purchase one there if you choose to do so , we don't believe in core charges , its a outdated and stupid business modle bottom line ...
- includes the following perks and extra's that are needed and required , again this is a KIT FORM ,,,,,,,,kit
- updated OEM Yazaki Japan parts Pigtail , black wire / w white tracer stripe , updated to the later 3FE 12ga wire size , with 3M heat shrink butt connector too
- this then creates a extension cord of sorts needed to extend the key switch solenoid wire described above able to reach around to the remote location male Hybrid
encased male spade terminal housing on the opposite side of the starter then a previous design old one
- New OEM Japan Mounting hardware , the form of 2 Studs , 2 nuts , and 2 spring washers ,
gone are the days of the clumsy course hex nut and holding a new gear reduction starter in the BENCH - PRESS position so it will not fall of and crush your SKULL like
on the WALKING DEAD ........
- Includes the now required for correct FULL 1.0 kw out put power , Cable Bond no. 1 kit , or starter grounding cable to top frame rail late modle feature and option , this in technical terms Polarizes the New updated gear reduction starter , with a dedicated home run NEG- FULL 2.0 AWG ANCHOR Marine brand fine stands tinned solid copper conductor /....
- original 1/75-1990 2F and 3FE and 3F carb Cable Bond's # 1 from the factory were only a puny 6 awg thick cable , this creates a light years ahead pleasant and reliable strong Engine Cranking Experience 24/7 .........
- ALL Starters and Alternators and Thermostat housings , water pumps , fuel pumps etc are Shot with 3 mist-kotes of 2 part marine grade clear koating to create a
extra layer of age and time ARMOR plaiting , that's both chemical resistent and UV rated , in other words i proudly call this added details matter feature :
" LIFE-TIME NOS in a CAN "
simply put is will NEVER Patina or form the typical little white dusty looking substance as cast bare aluminum will naturally occurs shortly after installation
in other words it ain't gonna rust ........
- that covers the unique to us gear reduction starter KIT we Exclusively offer up via our family run online parts store ...
- thanks for your support
matt
VintageTEqParts.com
vintageteqparts.com
GROUND STRAP KIT CABLE BOND NO. 1 Starter Motor to Upper Frame Rail Ground Strap Cable Incudes ALL Mounting Hardware Part# 90980-07003-R Fits: 1962-1990 FJ40, FJ55, FJ60, FJ62 , MUST HAVE when doing NEW battery cables we also offer .. - Vintag
MUST HAVE when doing NEW battery cables we also offer .. Reproduction part , Exceeds OEM Original spec's CABLE...vintageteqparts.com
