Gear Oil in Diff
Humboldt Nation
6 months after birf job, month or two after second wheel bearing replacement using :doh: trailer bearing grease I found
tube seal
and after all this
I'm left with this
No rust in the wheel bearings though one of the upper bearings on the knuckle had some on two or three bearings.
I didn't have any problems installing the original tube seal and thought it looked fine when I cleaned up the area.
Installed new tube seals, repacked the upper/lower bearings with moly, repacked the axle housing with moly and topped off the birf.
Did I bugger up the tube seal that bad or something?
More pics HERE
:cool:
you may have not set the inner axle seal set deep enough--that would explain the quick leak issue and washing out the grease so fast. The Marlin seal Inkpot mentions is alot wider in that area. Its hard to tell in the pic--but the lower portion looks to have the correct lip.......the upper may not have been flush.
When I set the seal in with a driver, there's a distinctive sound when it hits bottom.
:cool:
Buttoning up the front took a turn for the 'not better'.
Not sure what's up but I had a hard time getting that "satisfying" thunk when the rotor went on. The LH side went fine but I never did get that positive feeling about the RH side. I even went and bought a 4lb dead blow hammer. Worked well on the LH side only.
So I get the RH side on to a point I believe is correct, install the jam nuts, drive plate, etc. Now the caliper mounting tabs aren't aligned with the knuckle tabs. And the rotor isn't parallel to the dust shield like the LH side is. Like the rear of the rotor is tipped outward. Take the caliper, rotor off and reinstall. Same thing. Take dead blow to caliper as it sits on the rotor and got the tabs to line up. Couldn't get the bottom bolt to go in for nothing and gave up for the night.
After work today, I got both bolts in but the top one was unusually stiff after a few turn. Got the lower one snugged down and the top one was just plain stubborn. Four or five turns and let it 'cool' down. Repeat, rinse(just kidding) until it snugged down. It just didn't feel right though. Tires on and everything seems to turn fine. Take a test drive and for the first several blocks it seemed fine. Hitting the brakes hard at stops. Heading home down a stretch at about 30 and I thought a helicopter was over head but NO, it was me. Speed related scraping rotating noise and not much change when brakes applied. Crap.:mad:
It's dark now so I'll retire and try again tomorrow after work to bust it down and try to figure out what I've done. :confused:
:cool:
Bearing track not seated properly?
regards
Dave
Maybe. The plan is to tear the problem side (RH) down to the races and check to see if they are seated correctly and go from there.
I just hope the 'helicopter' wasn't something being ruined, but with that kind of noise the chances are something got hurt.:crybaby:
:cool:
x2
Probably the bearing race. When I did my front rebuild I heard a slight noise from the USDS. The inner race was just a little bit off. Once fixed the noise was gone.
What was 'just a little bit off'?
I was thinking I may have disslodged the race when I removed the bearing by knocking it out like you would the race. Not quite sure what I was thinking at that point but here I am anyway.
:cool:
I'm not sure what bearing track means, but IIRC, one observation I made when doing mine was that you can over seat the inner bearing hub seal, which pinches the outer edges of the bearing and prevents it from rotating freely around the hub. Of course that would probably show up when you set the preload.
Saturday I got the rotor/hub off and had a devil of a time getting the wheel seal out with out the 'proper tool'. Destroyed it.
After re-seating the inner bearing race( 3 wacks) I had to wait till Tues. to get an OEM seal.
Seal went in fine, seated just slightly less than flush with the top of the seal bore.
Rotor/hub goes on but I can't get that 'satisfying' thunk again. Try the jam nut, but with it at 47ft/lbs the rotor isn't parallel with the dust shield and the knuckle face.
Take the rotor off and looking from above the knuckle it looks like the spingle isn't at a right angle to the knuckle. The rear of the spindle base (or LH side) that mounts to the knuckle sticks out just a bit on the outer side but everything looks flush right where it mounts to the knuckle.
Tonight I'll take the spindle off and try to see if it's bent or just miss-installed.
It's not like this is the fist time I've done this. I may have underestimated the sneekiness of my inability.
Onward,
:cool:
When I pulled the hub, I could feel that the bearing was slightly not parallel with the seal.
When I re-installed, I gave the new race a few extra hits on the installer tool. I checked both races very carefully to make sure they were completely seated.
I noticed this as well.
There's a little lip to stop the seal when seated properly. Are you saying you drove the seal past the stop? That would seem to me to deform the seal.
Well, one thing I do know now: if you don't get the birfield in correctly in the first place, nothing is going to be correct from there out.
And why do I bring this little nugget of info up?
Most of my whole problem has been a incorrectly installed birfield.
I had a nagging feeling that I didn't pay as much attention as I should have when I installed the birf. The flat spot don't you know.
Sure enough the flat spot was at 2 or 3 o'clock. Reinstalled the birf properly and everything else bolted up just as you'd expect.
Now the inner wheel bearing race being 3 wack out of place and the caliper pistons not depressed all the way also contributed to my problem.
Never underestimate the sneakiness of ones own tardism. I did.:bounce::bounce2:
Sure feels good to get this behind me.
:cool:
Did you damage anything with the birf mis-installed?
Sure made a heck of a racket but I think things are ok now.
Went down to the Eel River Clean Up to day. Everything seemed fine.
:cool:
I would keep a close eye on your fluids, to make sure you didn't muck up the seal. Glad to hear it all turned out to be fairly minor.
Yeah, I'm going to drop the front diff oil soon. Hope those inner tube seals hold this time.
:cool:
:cool:
Just out of curiosity, how that spot can be installed incorrectly? It rotates anyway. I thought this spot is only for sliding the birf into the axle with out removing knuckle. Am I wrong here?
Yes, I believe you can turn it without removing the knuckle(I did not know this at the time). The FSM says to install with flat spot up (and that's before the knuckle is installed) and when I finally did that to the last side everything fell into place like I knew what I was doing.
:cool:
