Hey all
Over the past few months, I have been getting a progressively louder gear noise coming from the transfer case over ~20MPH...Here's some more info:
1.) TCase work done by a local shop approx 5 years ago (overhaul w/new shims, bearings, races and seals)
2.) Gear noise only when under load, no noise when off the gas; seems louder under light load (coasting w/gas on flat surface or downhill, uphill doesn't seem to be quite as loud)
3.) Noise gets progressively louder with speed, but does not change with shifting of tranny
4.) No difference in noise level or relation with speed with hubs locked or unlocked, 4WD or 2WD
5.) Vibration can be felt in transfer shifter that relates to speed/gear noise (IE more vibration when louder)
6.) Fluid level and condition check okay (low when noise first started but topped up, no burnt smell or signs of metal shavings after drain and fill)
7.) Rear driveshaft does need new ujoints, there is a decent amount of play in any direction on the rear DS
I'm thinking (hoping) this could be a bad output bearing, but I also know nothing about transfer cases. Does the rear output bearing sound like a likely culprit, or could it be a gear or set of gears that are not meshing just right? Or, could new ujoints on the rear and a driveshaft rebalance solve the issue? Those should probably be done anyway, as I have no idea how old the ujoints are, and they're definitely worn out.
To that end, if the rear output bearing is a likely culprit, is this something able to be replaced in the driveway, or is this professional shop territory? I did just finish a double steering knuckle rebuild and inner axle seal replacement so I'm feeling a bit confident from having done that, but the TCase is new territory for me...
Hopefully I painted a good picture of what I have going on here. I can also take and post video if that would help. If anyone can decipher everything I just put up and has some tips, I would love to hear them...Thanks in advance!
