For alaskan use, if you have a 2F in the rig, you will be much happier with closer ratios the H42 (or H55F or even H41) than you will with an SM420 or 465. Even with to hop up work the powerband of the 2F is fairly narrow and the wide spacing of the 420 and the 465 is a little bit too much for it.
I would not try to use 5.29s in a semi floating rear end. I'm got a set of diffs w/5.29s on the table right now going into a pair of front and rear (full floater) axles. You would have to grind a LOT from 3 or even 4 teeth to fit the pinion shaft in a semi-floater.
If you have a full floating rear, 5.29s and 38s would be just about perfect. Just about equal to OEM tires and gears. It will be turning pretty high running down the highway to the trailhead. But if you're working with a semi-floater, 488s will work great for you too. Especially if you swap in a three speed T/C. The 4.88s wil be a little more highway friendly too.
An orion is hard not to like. But realize that since 4th gear low range will be just a little lower than first gear high (assuming an H42), you will spend a lot more time in high range on the trail than you have in the past. You will see a lot of first and second gear high range with many drops back into low range when you hit the more technical stretches. But on our trails there is usually a lot of distance to cover by the day's end. That back and forth can get irritating.
The 5.29s I mentioned above are going into a '40 with a built 2F. I have an Orion that was slated for another rig, but will probably go into this one. I'll have to make my mind up in within the next week or two. I'm running 39.5 boggers on this rig and I'm not sure that I won't prefer the gearing of the three speed T/C. Crawling is great but when you've got a long loose hill to get to the top of or a wide deep bog, wheel speed is your friend. I'm gonna give it a try and see how it works overall.
Mark...
