Gear Allignment In Transfer Case?
Altoona, Pa
I am mating a four speed tranny to a three speed transfer case. I noticed when I bolted the two together that the input gear in slightly forward from the idler gear(probably about 1/32"). I haven't installed the rear transfer bearing yet but measuring it also appears it is going to protrude slightly on the inside of the tcase. It seems to me that I need a spacer washer between the tranny and tcase to push everything back slightly. Any thoughts or help would be appreciated.
Welcome.
Did you remove the spacer off the rear of the four speed trans when you took the tcase off, or did you just recieve a trans, sans case?
It was all together but there was no spacer. However, I did notice that the three speed tranny and tcase had a spacer washer when I split those two.
Where was this spacer located?
No, the four speed didn't have one on it when I split it from its tcase so I put it back together that way with the three speed tcase. However, it look like I may need one.
For some reason I remember reading something about this issue when I put the FAQ together on it........looking....
edit... NOPE.
Ok...
Thinking about some things here...
Does the tcase input gear hit the inner side of the tcase and move on the trans shaft?
The rear tcase bearing may sit inboard into the case just a bit...
1/32" of an inch misalignment is not really THAT big of an issue...
If the input gear bottoms out against the rear bearing in the trans, and does not move and rub on the tcase...I think you will be ok....
-Steve
Steve, I'm thinking that I've seen a number of the 4speed tailshaft spacer sleeves that have a groove in them where the imput gear rides up against it. The groove often gets to 1/32nd or better. I've got a couple in the shop where the groove has got to almost a 16th.
Usually if you are attentive it is just a matter of turning the spacer around and letting the grooved side run up against the inner race of the rear output bearing of the tranny, giving the 'good' side to the imput gear of the transfer case.
In any event, I agree that 1/32nd isn't anything to worry about. Unless it's freeplay in an Orion!;p
Amen
Time for a new spacer.
Wasn't there a shouldered spacer between the 4 speed and it's transfercase, shoulder forward to the output bearing of the trans? If so I'd use it, even though 1/32" isn't a lot.
I never measured for this but it seems like there's little difference between a 3 speed and 4 speed transfercase at the input.
