gasket cover parts
I have a very slow leak and would like to know the correct part(s) number so I can order online. I'm noticing few different numbers for my 2005 so I'm a bit confused as to which ones I should get.
There's more than one gasket in the engine, guessing you're talking about valve cover gaskets and an oil leak. Enter your VIN into a site like partssouq or take it to your local dealer and that will show you the correct one.
Thanks for the info. Below is what I've gathered and cross checked w/ PartSouq.
Cruiserpatch also recommends replacing PCV valve kit.
Cover gasket parts:
Cylinder head cover gasket RH 11213-50031
Cylinder head cover gasket LH 11214-50011
FIPG 103 seal packing 00295-00103
Spark plug tube seals (8x) 11193-50010
Valve cover bolts w/ rubber seals (18x) 90080-10330
PCV valve kit: production date 08.2002-08.2005 (non VVTI):
PCV valve (1x): 12204-50030
Ventilation valve cover (1x): 12236-50010
Ventilation hose (1x): 12261-50050
Ventilation hose no. 2 (1x): 12262-50080
Hose clip (2x): 90467-15021
Hose clip (2x): 90467-20010
