Gas Tank Pads
Does anyone have a picture of the proper placement of the gas tank pads? I ordered the rubber replacement pads from SOR, but I'm not sure where they go. Do they go on the tank itself or on the tub underneath. Prior owner used shag carpet on the tub, but that can't be right.
Originally it was 3 felt pads that were used. And they more often than not, they held moisture and left a rust spot which should give you an indication as to where they were glued to the tank... It's hard to explain, but it's in the curved step down on the tank, not at the bottom, but more on the sides. Does that make sense?
Carpet will hold water = no good. I use sections of bike inner tubes, placed at the high-points of the tub under the tank so it could still drain well around them.
Did you put them on the curved portion where the gas tank tray connects the floorboard? Or did you put them on the flat raised sections on the bottom of the tray? It seems like if you put them on the curved piece, that might restrict water flow. On the other hand, if you put them on the bottom, then it may shift from side to side in the tray.
So, you're saying that they're attached to the gas tank itself, not the tray that holds it in the tub?
On the bottom. I don't see how they could move. Maybe you're saying the tank could move a little? Maybe. If you ever tried to move one around to get the hoses connected and to get the tranny cover bolts in there you wouldn't be too worried about it.
I used pieces of neoprene (cut into squares). I don't think the location needs to be that exact -- the idea is to provide a small amount of cushion and space between the tank and the floor.
Tank Pad Placement
I guess I should have asked what year. Mine is a 72 and I just replaced them last month. You can see in the photo where they were attached to the floor pan. There were four of them, felt, spaced evenly around the pan. They are the brown rectangulaar tabs around the inside edges. The one in the upper left in the photo is pretty much gone, but you can still see where it was attached. Note that if you buy the SOR cushions that you'll need four of them. I thought it was a kit and ordered one. Bummer. I cut up old rubber Toyota floor mats to make the other three.
Thanks. Mine is a 76, but I think the tub configuration is the same. Only difference might be that mine has the gas tank cover instead of straps.
I get 1" dia. rubber stoppers, cut them into round slices about 3/16" thick, and glue them strategically around the tank. They work great; they don't absorb water, they don't squeak, and they keep the tank positioned clear of the tub and the tank cover.
Go to home depot and get some of these... They are like $1.00 a piece. They are in the plumbing section and come in different thickness.
The pic below shows them after I cut them to shape for the roll bar. Anyways good investment.
Fast Eddy said:
Those block the channels. I'm not a fan of that placement.
What blocks the channels? If you are talking about the rubber pads, you can cut them however you like.
Tank Pad Placement
OK I had the same question about placement on my '71. I think mine had the 3 felts that I replaced back in '83 or so when I popped in the 350 motor. Yes mine looked a lot like your pic there as I am now replacing pads after the paint job. There were 4 generations of dog fur under the tank, pine needles, beer can pop tops etc but very little surface rust. Back then I replaced them with heater hose cut lengthwise and flattened with electric tape. I don't remember doing it but it has worked perfectly over the years. This time I'm gluing in cut sections of radiator hose as it has good thickness and will use 4 in the pattern you thoughtfully provided. Dang you beat me out for length of ownership. I did buy my first new in '71 but kept it 3 years. I was very lucky to find my present 40 back in '80 that was low miles and excellent shape. I'll not make the same mistake again! i gotta dig out my old pics one of these days. I like those pics of you and your wife! I bought this '71 and the girlfriend and I went to pick it up together we got hitched shortly thereafter and she's still my shotgun rider in the FJ40
Hardware stores carry this ribbed rubber matting that works well. I like it because putting the ribbed side against the gas tank allows moisture to drain away. It's 3mm thick.
You could see where the factory pads were on mine based on the rust. The stock felt pads wick moisture and this is what happens. This tank got pulled because of pin holes. For the new tank I used small strips of generic rubber weatherstrip that would not wick up moisture.
Truck tire flaps make a nice, but thick material for this use. I have both the ribbed shown above and non ribbed drawer lining, plus the truck tire flap I found. Either way, it's gonna be a rubber pad.
