Gas sending unit screw
Swanzey NH
Anyone know what size and thread pitch are used
to fasten the sending unit to the tank (74FJ40)?
4mm?
I know that I picked up a bubble pack from the HELP! section that had a hex fastener in it that worked...instead of the phillips head screw...they were ford ignition module screws...iirc.
Been searching on-line for HELP! crap and cannot find a listing of their stuff...
I have the pack at the shop and will post the # up in the AM.
-Steve
Picked up 5 4mm screws, 12 pitch and they worked fine.
Thanks!
lane
I have a related question. I have a fairly strong gas smell in my 1967 FJ45. Can't find any obvious drips, but there seems to be a very slight leak around my sending unit. When I wipe my finger around the unit on the top of the fuel tank, it smells like gas. The smell is tronger when the tank is full (for now, I'm keeping it below half until I diagnose and fix the problem). The gasket between the sending unit and the tank looks like one of those cork/fiber types. Is that the correct material, or should I switch to an elastomer?
Thanks.
Thanks.
you can bet - when the tank is full and sloshing - it is seeping out from the gasket. cork is correct BUT when I replaced mine i had this issue with the cork, so I went to black RTv - no more issues, no more seep, no more smell. bingo.
Thanks for the info. Could you tell me more about the black RTV gasket? did you make it yourself? If so, what starting material, etc.?
Thanks in advance.
Black RTV is a level of silicon type RTV you lay (squirt) down and form yourself. 'Black' version is just nice for high heat and long life and very resistant to chemicals. You can buy it at any Napa or Pep Boys type automotive joint.
good details here: http://proseal.supergluecorp.com/80044.html
Thanks much for the link, wantatlc. You made my day. I'll let you know how it turns out.
no worries....
disconnect wires and unbolt sending unit, clean/sand around the rim of the tank (make sure not to get grit into the tank), clean and prep around the rim of the sending unit also, clean off the screws, lay down the RTV onto the tank rim, maybe a little RTV on the sending unit rim just to be safe, bolt down, clean up excess RTV that squirts out, hook up wires, let dry.....
I won't be able to get to it until Saturday, but with your advice, it should be a piece of cake.
