Gas Light stays on.
Beautiful Santa Barbara. CA
Hi Cruiser and LX gurus,
My 97 LX has the low gas light turned on even after a fill up. Anyone had this problem or even heard about it or seen a thread? I tried going till real low and filling up after but no change. Any advice is appreciated.:cheers:
Thanks,
C.J.
Just a dummy guess here:short or mecanical prob with sensor in tank...Prolly could cut the wire rather than have a big job (again I assume )pulling the thing Or do what I do in the studio,put a bit of tape over the stuk light LOL
Again I know squat but it sounds good,dont it??
D
PS: I hate those warning lights too I feel like they burn a hole in my forehead after a while. I ve been wrangleing with an on again off again CEL for months trying to get my EGR happy........It actually affects my mood is this normal people?
Hey it keeps my mind off who is running the country right now.eh?
I assume the gauge shows actuals when you fill (E-F range working).
If so your sensor/light is bad. Not sure where that would be located without looking it up in the FSM.
got schematics I could fax you a few pages if you're a tinkerer
D
I am not sure the proper testing method but the low gas sensor is separate from the gauge and is located on the pump/sending unit. You would need to pull the 2nd row seats lft the carpet and remove the access plate. Follow the FSM recommendations for pump removal.
I had a similar problem. My low fuel lamp would partially glow (read - not as bright) at random times.
I traced the problem to a loose ground.
Like THC2FLY said, you need to pull the seats and carpet. Pop that access plate and start checking.
Boyd
I had the same problem a while ago. Replaced the sender (in the tank) and still had the problem. Turned out to be a short within the bulkhead/cover that both senders are attached to.
There's a thread here somewhere that helps troubleshoot it (search). Got the necessary parts from Dan-The-Man (call him).
You'll need to remove both 2nd row seats to access the cover.
Thanks alot for the info fellas. Since I have not done any mechanical work on my LX by myself I will try to get some help from someone who's a mechanic OR Are there any cruiser heads in Southern Cali near Santa barbara? Who can advice me on how to do it myself.
When you said the bulkhead cover does it mean it's the cover that's on top of the fuel tank that has the two sendeing units attached??
Thanks,
C.J
