Gas in oil
Clemson, SC
Well fellow cruiser heads, I finally got my 68 fj40 runnin and stoppin. The other week I changed the fluids and when I got to the oil I found that I had gas in it. Not sure how much but you could smell it. Is there a solution to fixin the problem? Obviously replacin the rings in the pistons will stop it, or so I think it will. Is there anything easier, such as switchin to a different oil, or somethin? Really don't have the cash to shell out to get the rings replaced. So any help will be greatly appreciated. Thanks in advance.
Yup. Fuel pump diaphram leaking.
i have ruined a 2f and a 350 the same way
the fuel pump is always a good part to replace with an old motor
cool, thanks for the info. I replaced the fuel pump a while ago, but I had to use the original bottom half with a new top half and diaphram. I'll pull it out and check to be sure it has a tight seal and that I set it in right. Had to use the original bottom cause of the spring lever. The new one was built and the spring was like a CM taller and hit the engine block. Thanks again guys
