Gas Cap Door Won't Close
Sequim, WA
I've read through a ton of threads on the gas cap door and all I've found are about the door being stuck shut. Mine is stuck open, flappin' in the breeze and won't lock into the closed position. As best I can tell the pin/pawl is not sticking out far enough to catch on the receiver that's bolted to the inside of the door.
I looked at the backside via the jack storage compartment and there doesn't seem to be any slack in the cable, nor cable too tight. Can the cable be adjusted?
Or is it more likely that the pin/pawl is worn down too short? See pic. The end of the pin is angled which I saw one thread say it's not supposed to be that way.
Any suggestions for a fix, or do I just need to buy a new cable assembly?
Thanks!
