And now it is 70 degrees. Ahh Georgia... Heifer-net
Yeah... What season/month is it? I can't keep track.
As i was going through the gazillion jump drives Miranda and I have to clear them off an consolidate them, I ran across this picture of my old 60...the good ole days
This was at Tellico for a MLK weekend run in 2006 (Tellico was kinda hard when covered in snow)
BTW that is the original "Cattywampus" behind my 60, before it visited the butcher...
Hi guys need some insights here. Replaced bearing s and seals in rear end about 2 yrs ago and now this. Whst would cause it to go bad so quickly?
...via IH8MUD app
...via IH8MUD app
On the 4Runner in your sig? Check your brake fluid, I'm going with rear wheel cylinder. My mini did the same thing a few years ago. If that is it, go with OEM, I went thru 3 parts store ones before I ordered one from Sam, fixed it right up. Pull the drum and take a look at the shoes, those are probably gonna need replacing as well if it is the cylinder.
...via IH8MUD app
Went out to look uner hood. Looks like fluid is low in mc. Akso here are 2 pics of fluid. I is generally clear but smells a bit like gear oil. The clearness and low fliud in mc lead me to suspect rear brake cylinder. Thoughts?
...via IH8MUD app
Some of y'all that surf a lot more may have already seen this long before now, but if you haven't, this is some amazing driving - And I don't say that too often.
I was gonna ask which spotter you meant, but then I realized that the one on the ground jumping outta the way was much more likely to have something exiting the area in question vice the guy riding who definitely was puckering as you alluded to.impressive! Bet the spotter is still picking his panties out of his arse.
So far so good. Starting to plan my trip to the Marlin Crawler Roundup. Josh's wedding had better not interfere!How's Washington?
