G*D dam steering box!
Christchurch, New Zealand
I (lol my wife:grinpimp:) noticed the other day that the steering box had started leaking on the Cruza:mad:
I checked it over and found that the front input seal was leaking.
I got hold of my local Toyota dealer and ordered a seal.
This morning I thought a quick easy repair, remove the steering shaft and the old seal and pop the new one in.:rolleyes::rolleyes:
OMG I wish!!! The seal sits on the inside of the steering box. So out it came. Stripped it down, replaced the seal.
Now the assembly....:eek::eek::eek::mad::mad::eek::eek::eek:
I wish it was as easy to reassemble as it was the strip. It took us about 3 hours to get the worm drive and all its balls back together:crybaby::crybaby::crybaby:. My wife and I ended up sitting on the floor and we finnaly got it together so it doesnt keep jamming!:D:D Now cant wait till tomorrow to get it back in;).
Well got up extra early this morning to refit the steering box:rolleyes::D
Everything went surprising well:D
Filled the res up with oil and started her up!! and no more leaks:D:bounce::bounce:
Would it be possible for someone to post a concise write up of the process for rebuilding the steering box with pictures and a clear explanation of the re-installation of the worm gear and the balls? I have been researching this repair in preparation for doing this to my truck, but it sounds like a bear to reassemble, and my patience isn't that great. Thanks.
An addendum to this, I called the local Toy dealer to inquire about the seals for the box. The guy said the main seal kit is $155. and there are two additional seals in the top part that are $2.96 and 6.30. However, he said if it's leaking at the seal where the steering shaft enters the box, he can't even get that seal and would have to sell me the valve assembly for $622. Guess where mine is leaking? A new gear box is something like $2000 I think, so I'm not sure what my best option is. I don't think I want to buy a used box because too will need seals one day. My leak is getting pretty severe and I'm afraid it will just start pouring any day.
Call Cruiserdan. All those parts are available. I rebuilt my FJ60 box using the 80 series manual. They haven't changed in a meaningful way. Or send it to West Texas Offroad and let them do it.
The complete seal kit is about $150 as I recall.
...However, he said if it's leaking at the seal where the steering shaft enters the box, he can't even get that seal and would have to sell me the valve assembly for $622. ...
That's where mine leaks. Steering starts to whine after about 4 weeks, and I top it up with about 3 ounces of PS fluid.
That's fine. The leak is constant, but not increasing. At this rate, it will take me about fifteen years to spend the same in PS fluid as I'd have to spend on a valve assembly. Guess which direction I'm taking... :hillbilly:
Wow, does your wife have a sister?? :D
Sounds like a good couple therapy project.....
maybe you tried, but I saw a thread here a couple weeks back about ATF being the cure for some PS leaks. worth a shot?:meh:
Steering box...leakage
Recently found out (was told) my steering box has slight leak at the bottom. They want $857 for a second-hand box...
Was told that putting in new seals was not worth it, something about high-pressure and they would just blow again.
It's not serious now, but wanted to get a read on people advice...I suppose I could order the kit from the USA and try and find someone here that will do the job.
I have the kit and will be getting around to a rebuild here someday. My leak's getting pretty bad.
I'll let you know how easy it is.
As far as "high pressure" making a rebuild short lived, I call BS.
I haven't had an 80 box apart but if its built like a 60 box, changing the input shaft oring isn't that big a deal. The hardest part is getting it reassembled with the correct preload on the input shaft bearing - no need to tear the whole thing apart. In fact I could do the oring without even removing the box from the truck.
