fzj80 RADIATOR SLUDGE
Charleston S.C.
Website
www.lextechautomotivellc.com
Thought i'd pass this along for all those with fzj80's with overheating problems at highway speeds and turning the heater fan brings the temp back down.
This is the sludge that everyone is refering to that builds up in the radiator. Flushing the cooling system will NOT remove this sludge.
Can anything remove that?
A radiator shop can clean that out. I broke the nipple on the upper rad tank and opted to have the tank replaced instead of a new rad. When he opened it up it looked someone had poured river water in it and was full of silt so he cleaned it out.
Howdy! Nothing wrong with that radiator that a good boil/rod out won't fix. Might want to replace that tank though, I don't think JB Weld will hold on that big of a spot. John
What year is the one you pulled the rad off of and what are the miles on it?
I have had almost no problems with our cruisers since we started running gano filters.Clean the filters about each week at first then its about twice a year. In Dallas heat we just dont over heat anymore.No add on coolers or extra fans. Mike
wow i bet mine looks like that
Mike- would you mind posting some details about your filter setup?
As most people that follow my responses know typing and pics are not my strong point I would even describe them as needing improvement. My GANO filter I bought out of the Specter Catalog,yes I know they are not easy to deal with but I have rarely bought junk from them either.It installs in about 15 min. in the upper rad. hose.I do wish Specter would send me their catalog which was supposed to come with my sons last order,but any way. We use them on our cruisers. Just dont tighten them down with a socket wrench use a screw driver. Mike
The sludge is greenish color so sometime in the past, a switch from Red to Green took place w/o a proper and thorough flushing is my guess!
So by adding the filter to a 15 year old radiator and system will help it? Should you flush it first?
If there is sludge embedded in the radiator, a filter will not help with that.
But it *WILL* help keep it building up more sludge.
if this Gano filter includes just this mesh screen as the drawing suggests, it won't do anything for real fine sludge. But perhaps there is paper too. Unlikely cuz dangerous. Of course, having something that can be plugged located inline seems like a very bad idea to me.
Lextech, this pic, is that of the bottom of the rad? If so, how did the top look like?
Very good point. I just finished the radiator flush the past weekend, and looked into the radator cap hole and it looks a layer of "coding" similar to pictured. The truck had always serviced by either Toyota or Lexus dealers, but I guess at one point someone must have gone cheap with different coolant - wish I had paid a bit more attention to these things. :bang:
Anyway, will any of the radiator cleaner work for removing sludge?
